71 C25 - Motor/Tranny suggestions requested
Hi folks,
i'm new to the forum and looking for some advice. I have a tired 350 with a turbo 350 in my 3/4 ton. I would consider myself intermediate on the mechanical side. I have a 3 ton hoist to pull out something and put something in. So what is an economical power solution? Thank you! |
Re: 71 C25 - Motor/Tranny suggestions requested
If the 350 is in fact worn out I'd say your most economical solution is a long block from a reputable local rebuilder. You should be able to get that for under $1000.
What makes you think it's 'tired'? I've bought vehicles that the PO was going to do a rebuild or replacement on but the motor just needed some attention. Tune-up, etc... P.S. Welcome to the board! |
Maybe I should edit the comment, she drives likes she's tired. I don't expect too much from her as she is miss dependable. Lots of leaks, rear main, valve covers are leaking...she deserves some pep as well.
I just watched this and now I'm drooling but I think that contradicts my economical comment. http://www.powerblocktv.com/episode/...p#.Vz9cuo-cElw |
