Tig welder
I have been wanting to buy my own welder for a while and now that I have my 70 k5 project I NEED a welder. I have been mig & stick welding for a while now - my dad has both and I can use them when I need to fab something. I've done a lot of research and really want a tig welder because we don't have one and it will allow us to weld aluminum & stainless. But how practical will it be to use only a tig welder for floor repair and body work on the blazer? Main thing the blazer is at my house and I don't want to have to take it back and forth to my dads to use his mig or drag his welder to my house.
Thanks for the advice Tom |
Re: Tig welder
I love using TIG on body panels. I tack them with the MIG and complete with the TIG. The metal finish time is greatly reduced even though the welding takes longer.
For car repair I'd want both. |
Re: Tig welder
Maybe I should consider a multiprocess welder like:
Miller Multimatic 200 or Lincoln MP 210 Both are mig tig and arc Both are DC only so aluminum won't be possible but I can live with that. Anyone have a multiprocess welder? |
Re: Tig welder
I just bought the Miller Synchrowave 210. It is easy to set up and welds very nicely.
The torch is almost like holding a pencil and the lead is very light. It came with stick weld and spool mig weld attachments too, though I doubt I will ever use them since I have welders for those applications. |
Re: Tig welder
You can weld aluminum with DC and helium but it doesn't come out as pretty and the cost for helium makes it not worthwhile for most of the stuff we are doing. I bought the AHP Alphatig. Had a bit of a hiccup at first (bad torch) but ultimately replaced it with a CK9 and have been happy as a clam since. I tig my body panels (and pretty much everything I weld in my garage). Here is my bedside I shortened: http://i20.photobucket.com/albums/b2...110_180404.jpg |
Re: Tig welder
Re: Tig welder
What's your process on tig welding the panels...........it looks like you stitch in what ? about 1" increments?
Re: Tig welder
Ive got 3-4 80cf bottles through it. Used all the features. No issues yet. Quote:
Nice thing about the tig is if your gap is too big you can usually use a thicker rod that fits in the gap and freehand weave it in. I put most of the heat into the rod to avoid warping and let it wash over the sides. |
Re: Tig welder
Re: Tig welder
Definitely order the CK9 torch unless you are used to using a 17 (Its huge and harder to work with).
I have two helmets. I use a harbor freight for my mig welding. It will flash you repeatedly if you try to use it tig welding. Amazon had a great deal for almost half price so I bought this one: 3M Speedglas Welding Helmet 9100 with Standard... I cant say enough good things about it. My buddy used it once and went out and bought a new helmet. Just to note though, my old welding instructor (welds for a military contractor) uses a big screen fixed shade. Says it works better for him (just his two cents). |
Re: Tig welder
So my buddy bought an AlphaTig recently and I got to use it for the first time. I like to use A/C aluminum welding as the "judge" of how good a tig is, since to me, its the defining reason to own one.
The Good about the Alpha;
I'd say for a weekend warrior, its a nice unit. You can always upgrade the torch, pedal, and regulator as they use connections that are common enough in the industry that you can use the "big" guys parts. The only real competition for it would be the low-midrange welders from Everlast like the 185ext. Their torch and pedal are nicer, and the regulator is generic but of decent quality with a flow meter. Its about $300 more, but with the torch pedal and reg, its nearly the same cost. Your only advantage there being the brick-n-mortar support for returns and warranty thru HD/Lowes/Neus |
Re: Tig welder
Right there with you for the torch and peddle. I replaced my torch but just spun the peddle around and it works fine for me. Mine came with a flow meter not a regulator though. It reads a bit higher than it actually flows. I have a small torch meter that you put over the end of your torch to get the actual flow.
I was thinking about ordering a dual feed meter but I think I am going to just by a second tank and get an additional meter for it. I dont always get a chance to get to the welding shop and a second tank will serve me well. |
Re: Tig welder
The Jackson nexgen is a great hood for tig welding. I think it picks up down to 2 amp tig. I use my nexgen for everything. Very clear adf. I've never used the 3m speedglass but I havent heard anything but good things about them.
Re: Tig welder
Try the Lincoln Viking 3550. Much clearer than my Nexgen. better color same price
Re: Tig welder
Re: Tig welder
Yall know me and shameless self promotion. I did a review on the Miller Digital Elite helmet. I like it a lot for the money.
Re: Tig welder
Viking 3350 is good helmet I have owned it for about 4 years and reviewed it as well i opted for that over a digital elite at the time because back then the digital elite had a smaller screen and the digital infinity helmets which have an equivalent sized screen weren't out yet. The only change i have seen so far is the headgear has been updated mine broke once in 4 years the new one appears to be more like a miller elite headgear with more adjustments but i am still on the older style and it works fine.
Re: Tig welder
I wanted an entry level tig machine and a couple of years ago I was at my welding suppliers........they were demonstrating a Miller Diversion 180 tig machine....it fit the bill for what I wanted at the time so I bought it at a discount because it was a demo (only one time).
My primary business is high precision CNC machining but occasionally we need to tig weld something....I always had to send it out to a welding shop. Now I can do most small tig jobs in house....not to mention my hobby stuff too! https://www.millerwelds.com/equipmen...ion-180-m00337 |
Re: Tig welder
IMO you can not spend too much on a GOOD helmet if you weld much at all. Once your old and blind like me you want something with a WIDE lens and a 1.5 or 2 power cheater!!!, and some LIGHT so you can see WTF your doing. I spent a bit at cyberweld.com but it's amazing what a difference a GOOD helmet makes.
I bought a Digital Performance and added the light and cheater lenses. It's is all I need for the Miller SyncroWave 200. I've welded stainless, aluminum sheet steel, and even some crazy alloys I didn't know what it was. I'm by far not a 'good' welder, but the right equipment is a MUST if your going to stand a chance to learn. Funny a GOOD experienced welder seems to be able to make a BEAUTIFUL weld with a $49 Harbor Fright POJ.,, but as a novice i need ALL THE HELP HE CAN GET!! http://www.small-block-chevy.com/ima...weldHelmet.JPG http://www.small-block-chevy.com/ima...s/holymoly.gif that's a huge picture,, try it as a linky dink |
Re: Tig welder
Which light would that be? |
Re: Tig welder
Its a Nitecore
Originally a headlamp for running biking gear or something, I took it apart and mounted it to the hood and tossed the crap I didn't need. They don't sell the 'exact' model any more but I bought a 'package' with 4 batteries, charger, and the lamp. like the link. This light is Insanely bright and has a focus to narrow / wide beam. Batterys are STUPID expensive individually so try and get one of the amazon 'packages' with spare batteries and smart charger. The new packages are way more expensive ,, new and improved I guess. LOL I can run the light well beyond any welding project I have on one set of bateries. And light up the WORLD. LOL |
Re: Tig welder
Quote..., I took it apart and mounted it to the hood and tossed the crap I didn't need.
Post up a picture of it on your helmet if it wouldnt be too much trouble. Thanks, Tom |
Re: Tig welder
You bet
the picture is the link above. it's pretty huge so I just put a link http://www.small-block-chevy.com/ima...weldHelmet.JPG |
