K5 Blazer/Jimmy Side Window Rubber/Gasket/Flocked Channel
Just wanted to share some info I've gathered during our restoration work on my Dad's '78.
A good replacement rubber (filler plug) for the interior trim of the window frame (not the flocked window gasket) can be purchased from Duncan Systems (Part #2-132-014470): http://i1260.photobucket.com/albums/...psgfstlxj0.jpg The product was inherited when Duncan Systems purchased Atwood Mobile a few years back. For the flocked window channel, I purchased from Metro Moulded Parts, Inc. I need two (2) WC-22 96" and one (1) WC-22 48" to fill the gaps. You really need a 108" run for each side, but I couldn't find any custom lengths. I think there are some good options if you just check with your local glass shop. https://www.metrommp.com/productimages/640/WC2296.jpg |
Re: K5 Blazer/Jimmy Side Window Rubber/Gasket/Flocked Channel
Link: Duncan Systems
just bought a 86 K5 for my son and I to work on together. last night I ran into this issue with the sliding windows. felt for the window guide/slide is falling apart and basically gone now and it binds up the sliding glass. Like I have read nobody including LMC seams to have it. buffydores your saying that WC-22 part # from Metro moulded parts worked well for those window guides?
Like buffydoers I found a door channel that works as a good replacement for the side slider window seals. I got mine from DK Hardware Supply – they are CRL 60” Flexible Flocked Rubber Glass Run Channels for 1965 – 1967 Chevy trucks. They are not long enough to do the job in one piece so I put one on top and one on bottom with the joint just shy of the front top corner. Worked out great and I am so glad I don’t have to listen to the noise anymore.
Thanks Darrell for the info. I did order what Buffydores suggested already so hoping that goes fine which it sounds promising with either option Thanks
Posted via Mobile Device |
