rear alum window rubber gasket
I need to buy a new rubber gasket for my 68 c10. Does the sliding alum window take the same rubber gasket as the glass window?
thanks Don |
Re: rear alum window rubber gasket
Can't say 100% for sure in other applications, but my aftermarket SRW used the same rubber as the original glass.
Every aftermarket slider I've ever seen is designed to use the factory rubber.
Thanks.....any recommendations of where to buy........Don
