interior lamp control module
Where is this module and does it go bad? searching for a battery drain and found the foot well and door panel light stuck on and can not turn them off.
Re: interior lamp control module
.... And the year of your truck is.......
Check the push-in switch, where your door contacts the side of your dash edge. Also see if that little "button" came off, that the switch presses against. If the button fell off, your switch falls into a hole. ( lights stay on) |
Oops........... 97
