Heavy Hauler transmission question
so I am looking at purchasing a early to mid 80's WHITE Tilt cab cab over with a perfect running 6V92TA in it to repower my 69 GMC 5500, what I am wondering is how hard is it to convert the remotely shifted Fuller T-11607A transmission to a direct shift?
Re: Heavy Hauler transmission question
I can't answer your question but I may be interested in your take out ....depending on what it is
the shifter is easy to change just get a shifter out of a conventional, unbolt 4 bolts and bolt the new one in. but I sure don't see how you are going to get a 6v92 ta to fit in a 5500.
also remember you will need to change rear end ratio. years ago had a Ln-800 ford with a 391v8 &5+2, change it to a 671& 5 spd over, top speed was 41 miles an hour.in hi range.:waah:
Same reason my C60 with a 427 is staying a gasser.....and it STILL will likely be a 50 ish mph kind of deal.
