71 blazer wheel stud replacement
After 45 years on the road and a total of 89k original miles I have decided its time to change the rotors and brake hardware on my old girl..
Who do recommend to purchase the studs from .. Thanks in advance Mike |
Re: 71 blazer wheel stud replacement
If you are referring to the front wheel studs for the Dana 44, they are Dorman 610-179. Available from Summit as a ten-pack for $20, and likely available at most of your local auto parts stores.
Rear would be the Dorman 610-186. |
thanks Rw
If you're going to replace them, I would suggest you upgrade the 7/16 " studs to 1/2-20. I did on mine because it's cheap insurance.
