New Product from AccuAir! Tank w/ Valves Inside
We wanted to share a new product that AccuAir has released. Some of you have seen this already, but wanted to give some info for those who haven't. They are releasing a 5 gallon 200 PSI, DOT approved tank with the valve inside! This makes for a very clean install. Also will include built-in flow controls. The 5 gallon tank will have a 4-corner valve system (2-corner in each end cap). The 3 gallon will have a 2-corner valve system, so the running a pair, will create the 4-corner system you want.
Because we are a direct authorized dealer for AccuAir, we were able to pre-order these new tanks, and will be the first to get them. We still have some left from our pre-order for sale, so make sure to contact us to get one sooner from this pre-order. Available in raw, black, gray or bronze finish. $749 for raw finish, with valves inside. (Compared to $630 when ordering separate valve and tank) Call us, PM or email us for forum pricing. sales@azproperformance.com 480-420-8175 http://www.azproperformance.com/imag...ernate%202.jpg http://www.azproperformance.com/imag...0Insertion.jpg http://www.azproperformance.com/imag...t%20Detail.jpg http://www.azproperformance.com/imag...%20Anodize.jpg http://www.azproperformance.com/imag...%20Anodize.jpg http://www.azproperformance.com/imag...%20Anodize.jpg |
Re: New Product from AccuAir! Tank w/ Valves Inside
That's slick! Where does the computer mount?
When using E-level or Switchspeed, it can mount to the tank using the optional Endo mounts, or wherever you would like to.
These tanks are getting closer to being released! We still have a few left over from our pre-order.
I think I want one. Are there any downside to going this route? How much for the speed switch or E-Level
I don't see any downside to going this route, other than the $119 difference of doing a regular 5 gallon tank and separate VU4 valve. It does clean up the system and make things more simplistic.
PM Sent for pricing. |
question
I have the Vu4 manifold and wonder if I were to buy the Endo-T if i could later add the compressor only?? |
and im wondering if there is a way to mount that Vu4 into the Endo-T
We have the Endo-T tanks in stock. |
