Stand Alone Harness
5 Attachment(s)
Blue Green Connector Harness off of 2004 GM Truck
Drive By Wire 4L80E Low and High Fan Grounding Tach / AC / Speed / TCC etc outputs Relays / Labeled / Fuse Box Basic Instructions This harness was worked by LSX4U / Just Chevy Trucks. I decided to do a custom length harness to move my PCM under the seat on my build / plus needed some different routing for the turbo piping. NO PCM INCLUDED $400 shipped |
Re: Stand Alone Harness
sent you a p.m.
Still available? if so, please PM me.
Thx |
Still available. PM sent. Thanks.
Pm replied, thank you
Harness is now sold. Thanks.
Were you happy with the harness and how much is the custom length one going to cost.
Sticking with LSX4U ? |
I think the custom harness was around $700. Didn't use LSX4U for that one - I believe they only rework factory harnesses. Larry's Electric did the custom harness. They are out of IL.
Check out speartech in IN. Built from scratch harness and ecm $750.
starting at $1600 for a GENIV http://www.speartech.com/product_p/58x4l-hp.htm the standalone harness itself is like $750 for GEN3. |
