1968-71 Doors
5 Attachment(s)
I have a pair of empty doors for 1968-1971 trucks that I got from a board member in MN. I know they fit 68-71, not 100% if they are totally correct for 67 and 8s. These doors have no rust through, just surface rust. There are a lot of surface rust spots probably from rock chips from what I can tell. Along the pinch weld is solid. There is some minor bulging in the pinch weld but no soft spots. There are spots on the skin that mirror holes were welded up. The LH door has had a crack repaired below where the upper hinge mounts. The welds need dressed and body worked. The LH one has a dent on the inside above the door panel. There aren't any other big dents in them. A light sand blasting and these will be really nice doors. $250 OBO for the pair. I will ship these through Fastenal or Greyhound at the buyer's expense.
See below. These doors do not fit a 67 unless you use a 67 door handle. Thanks to Cheyenne shortstep for that info. |
Re: 1967-71 Doors
4 Attachment(s)
More pictures of the doors.
Re: 1967-71 Doors
Any idea what shipping would be to Ohio 44214
Re: 1967-71 Doors
https://www.google.com/webhp?sourcei...20near%2044214 |
Re: 1967-71 Doors
Yes Wooster is
Re: 1967-71 Doors
If you can do 300 shipped I'll take them
Re: 1967-71 Doors
Just an FYI 67 doors are 1 year only in the outer door handle mounting [there is a plate inside for a straight into handle screw vs. angled to match contour of the door], the outer door handle is 1 yr only as well. As long as you use a 67 outer door handle you are OK. I can provide pics if anyone is interested.
The doors pictured are technically 68-71. |
Re: 1967-71 Doors
Re: 1967-71 Doors
Re: 1967-71 Doors
Thanks gunner
