1964 - 66 Auto column
5 Attachment(s)
This is for the column on the right. It is been taken apart cleaned, tightened, and bearings repacked. The shift tube is from a 67-72 Turbo 350/ 400 column. It has been shortened to fit this column. $250 plus shipping. Steering wheel not included in price.
Re: 1964 - 66 Auto column
Woody,
The column looks nice for a three speed automatic conversion, good price too. Attached are two photos, can you tell what application these auto linkage are for? Thanks, Les |
Doing the IPad so,only one photo at a time.
Les |
Do you ever make these for a four speed transmission?
Les- I'm pretty sure your linkage is for 63-66. auto with a powerglide
The Rocknrod - I have all the pieces to do a floor shift column if that's what you're talking about. |
How much to cali 92408?
Les, those are power glide brackets as mentioned, 63-66.
Rvrfoot- it will be this weekend before I can get a shipping quote on the column. Do you want this Center steering shaft with it? The price of the column is the same with or without, the only difference will be the shipping cost.
The Rocknrod- sorry, no I don't have the pieces to do an overdrive column. Can you get an overdrive lens for 63 - 66? |
No problem for this weekend to get a shipping quote and yes just to column. thanks
TH200-4R, TH700-R4 & 4L60 http://www.shiftworks.com/lens1.jpg |
I might have to try to do one. Just need to find an overdrive shift tube that will work
Column sold to rvrfoot
Hey....Looking for a 1966 Chevy C-10 Automatic column assembly...a virgin would be ideal.....would need it complete with wheel, turn signal assembly, shaft etc. ....several that I have found have been abused by previous owners.......has to be 64-66....Will be using with TH350 Trans......
5 Attachment(s)
Sorry, I don't have another 3-speed automatic column at this time. I do have this Powerglide automatic column with a 66 Deluxe wheel. $250 plus shipping on the column with or without the center shaft, $150 plus shipping on the steering wheel or $350 -plus shipping for both. They will have to be shipped in two separate boxes. The column has been taken apart cleaned and regreased, new lower bearing.
Can you provide a brief overview of the difference in Automatic TH350 columns and the Powerglide Columns.....whats so different? I realize the shifter indicators are different.......I'm confused....Thanks in advance.....
The powergilde only shifts 2 times and the 350 shifts 3 times.
2 Attachment(s)
The shift tube is made different but it can be used . You could only get an original 3 speed automatic column in 1966. And I think only in a 3/4 ton. Here's the only 2 pics I have in my phone showing the difference in the lower part of the shift tubes. The first one is for turbo 350/400. The second one is for a powerglide.
Hey...Southern Parts.....Thanks for the information and Lower Column Photo's...
I'll investigate in a few days and get back with ya..... |
Powerglide column sold locally
Hey....looking for a TH350 3 speed column.....know of a source....prefer a used OE model? Thanks in advance...
No help on an original 66, 3 spd. auto column. I'll keep you in mind if I find one.
Hey....how about a 67-72 Chevy C-10 3 Speed TH350 Auto Column and possibly a matching wheel ?.......Thanks....
I have a green one on the 67-72 parts board.
