72 suburban sheetmetal
5 Attachment(s)
This ad is only for the sheetmetal on the burb. Nothing else is for sale atthe moment. She is pretty rusty in a lot of places but there is still a lot of usable metal on it. Let me know what you need.
Prices start at $25 per cut plus shipping and go up from there depending on what you need. All the doors and rear gates are rusty . |
Re: 72 suburban sheetmetal
5 Attachment(s)
6-10
5 Attachment(s)
11-15
5 Attachment(s)
16-20
RH "B" pillar to 98409?
5 Attachment(s)
Take a look and see if it is good enough for what you need. Also let me know how close I can cut the top and bottom so I can get accurate shipping quote Richard . |
Almost completely cut apart. Let me know what you need. Broke my only sawzall blade. :lol:
Even got the plywood out without damage. Only the little pc up front passenger side was no good . |
The way you have it cut is fine, for shipping cut it again someplace between the upper hinge and the raised portion between the doors.
I also just parted one of these and had some interest in the frame body mounts and rear frame section so keep that in mind when scrapping it.
What do you want for that exhaust hangar at the far rear and are there any over the rear-end? I could also use a piece of the roof door jamb area, above the 3rd door would be best section if its clean. |
I have not decided if I am going to part the frame yet. I may keep it to put my 68 panel on. I will get some pictures posted in the morning of how I have cut the body up so far
What about the front door frames
3rd door frame with glass parts rear glass, both sides, door and fake door door panels |
Are the rear window regulators any good?
4 Attachment(s)
rear sill has a few rust thru spots but still usable. $25 plus shipping
3 Attachment(s)
Spare tire well would need bottom patched $20 plus shipping
4 Attachment(s)
Not from this burb but a pair I bought a while back. I ended up finding a pair of full skins so i won't be needing these. They have some dents but the outside skins are rust free.
5 Attachment(s)
Windshield pillars $25 each plus shipping
Gas cut out $40 plus shipping A/C dash there is rust on the ends and would probably be better suited for a radio patch. $100 plus shipping for full dash (was cut at dash pad) or $100 shipped for radio patch . |
4 Attachment(s)
Passenger side
2 Attachment(s)
Driverside
Interested in the above driver door frame cut in last picture from B pillar forward
How much for the drivers side quarter.
Richard, I' ll take the passenger side w/s pillar, does it look the same as a blazer
2 Attachment(s)
I already have these two sections cut and forgot to post them. They are from above the rear side windows on each side. One is about 37" and the other is about 39". I would need you to PM your shipping address for an exact quote but I am thinking it will be around $100-$125 for the 3rd door hinge post and one of these including shipping. Richard . |
I would imagine shipping would be real expensive LMK Richard |
the main part of the pillar is the same but it will not be the same at the top section, I don't imagine. I will compare it with my 71 blazer in a little while to see what if any differences there are. It may be just the horizontal top bar that is different. Richard |
