4.8L swap?
Has anybody swapped a carbed 4.8/th350 into a C10? Any idea cost and difficulty of doing this?
Posted via Mobile Device |
Re: 4.8L swap?
Lots of people (though usually EFI, not carb'd). Check the LSx Swap subforum for more info.
Re: 4.8L swap?
Im doing a 4.8 but not carb'd lol
https://scontent-sjc2-1.xx.fbcdn.net...10&oe=59549B98 Depending on if you have to buy a carb its easier and cheaper to go with the stock efi. You can get the stock harness reworked for around $500, compared to $650 for the MSD box and carb intake then you still need to buy a carb if you dont have it already. Other then that buy some shorty ebay headers for 150 bucks and a flywheel to hook up to the t350 for around $100. Stock oil pan and accessories will work. Use your stock radiator. Other then the cost of the motor you can do it for under 1K |
Re: 4.8L swap?
Re: 4.8L swap?
and are you DBC?
Re: 4.8L swap?
