Crome steelies
Crome steelies 6 lug local p/u only $200 I will get more pictures on saturday.Attachment 1635460 The tires are cracked.
Re: Crome steelies
3 Attachment(s)
Re: Crome steelies
Do the tires come with the wheels?
Re: Crome steelies
Yes
Re: Crome steelies
What is the date code on the tires?
Re: Crome steelies
I dont know i will need to go look at them. T he tires are cracked. Thay was running on my truck last week. I just got new ones.
Re: Crome steelies
When you have time to check the codes i don't need out of date tires for a trailer. What size are the tires & wheels.
Thanks Kenny |
Re: Crome steelies
Hello kenny, The tires are out of date. The tires size 235 75 15
Re: Crome steelies
I will pass I need tires more than i need wheels.
Thanks Kenny |
Re: Crome steelies
Ok no problem
Re: Crome steelies
do the tires have white writing on inside?
Re: Crome steelies
I donk think so i need to go look . The tires are cracked.
Re: Crome steelies
New price $100
Re: Crome steelies
Do you know the backspacing. If it will take disk brakes I want them
Re: Crome steelies
I will check on them when I get home today.
Re: Crome steelies
The backspacing is 4 1/8 i called brothers truck today thay said the after market wheels will work with disk breaks.
Re: Crome steelies
Not sure how you measured butt 4 will not work need to be 4 1/2. Measure from the outside edge of rim to the flat part that mates the hub or rotor where the bolts go through
Re: Crome steelies
Thats how i did it.
Re: Crome steelies
take the tires off and ship to NORCAL? zip 94015...how much shipping if you are willing to do?
Re: Crome steelies
ttt
Re: Crome steelies
still got them?
Re: Crome steelies
Yep
Re: Crome steelies
will you ship?
Re: Crome steelies
No sorry
Re: Crome steelies
These are known as Chrome "Smoothies" and "Steelies" are stock design with 4 vents and nubs for factory hubcaps (or clips for earlier).
Backspace has nothing to do with disc brake vs drum brake application. The difference is in the contour of the wheel centers and the aftermarket makes them to fit disc...which fits drum. 4" backspace is typical Good luck with your sale at a good price |
