Tight hood hinges
4 Attachment(s)
$25 + shipping cost, pp mo
Re: Tight hood hinges
I'll take them as long as they are truly tight. Did you happen to check them with the springs off?
I"ll take them if Glenn passes.
I still want them. Waiting on 6t727t2 to reply.
Glenn, lowest shipping rate I found for 17 lb from 08008 to 92663 was fedex $37.62
70stovebolt, best shipping 17 lb 08008 to 46590 was fedex 14.97 |
Have you checked the hinges with the springs removed? The reason I ask is that I just purchased a set that was tight until I removed the springs and found slop.
Glen, I haven't removed the hinges, I know that the hood opened and closed fine without any side to side movement.
Harry are these still available?, I'm just south of you so I'd assume shipping wouldn't be all too bad.
Thanks, Mike |
Hinges still available, $25 + shipping cost
hi what is shipping to 92648
Just get a flat rate box from the post office. It will be 18 shipped
A pair won't fit. Not sure one would in the current boxes they offer. Why would slop in the hinges matter with the springs off as long as there's none with them on and in use on the truck?
in line 14063
