Rear Anti-Roll Bar Setups
I'm looking for some pics of ARB setups on trailing arm suspensions. I'm running low 11's with 1.5x 60ft's and my launch is pretty twisted even with a 10 point 'cage. Looking at installing an ARB to level my launch. Any particular brands to look at? Thanks.
Re: Rear Anti-Roll Bar Setups
When I had factory truck arms, I made one with:
1 3/4" DOM tubing for the bar 1 3/4" sway bar bushings for an RV 3/16" plate steel as the leverage arms 1/2" rod ends with 3/4" tubing for the links to the frame It made a huge difference and was cheap. |
i dont have one because mine is a full Drag truck. that bed floor is super heavy. i have seen anti roll bars done several ways. upside down in cars with stock floors, etc.
2 Attachment(s)
I did a through-frame tube crossmember that houses a splined torsion bar for the rear roll/sway bar on my truck. I used some leftover sprint car torsion bar parts since I don't plan to drag race my truck very often. For a drag race truck, I would mount the torsion bar closer to the rearend housing, go with a larger diameter bar, and shorter arms.
