Need original steering u-joint seal 60 C10
Looking for new rubber seal for the steering column u-joint on my '60 C10, or entire assembly. I found a company that makes complete reproduction units of this assembly, but not for GM. I searched the web, including ebay, with no luck. Does anyone know where to find this? Thanks!!
http://67-72chevytrucks.com/vboard/p...ictureid=24242 http://67-72chevytrucks.com/vboard/p...ictureid=24244 |
Re: Need original steering u-joint seal 60 C10
Submariner616,
I was having a few problems with my 62's column also. It was basically just worn out and I didn't want to keep messing with it. I replaced it with an I did it column and i am so happy I did. No issues, and an easy install. The only thing is your still running a 3 speed on the column you will have to put in a floor shifter. |
It is very hard to resist the temptation to modernize this beautiful hunk of steel!! |
Wow, my '64 has a one piece rod. I just figured they were all like that. Is that a automatic tranny only deal?
No, it's just a '60-'62 deal.
We need to find the seals for the 60 62.
I'm reviving this old thread because I found a pretty much exact replacement for this seal and its readily available:
https://www.amazon.com/gp/product/B0...3AWUYIR8&psc=1 |
