k10 brackets frame brackets and crossmembers
5 Attachment(s)
here are some parts I cut off a parts frame. price is plus shipping unless stated shipped. if using paypal ad 4% to cover fees.
front frame horns straight no cracks 50 4 speed crossmember 100 v8 crossmember 100 67 k10 manual steering box not bad had a little slop. 1 year only box 75 exhaust bracket for drivers side frame rail 25 |
Re: k10 brackets frame brackets and crossmembers
Yes I do. I believe it's good. Will check. Do you just need it or the box too?
i need the 2 plates that were riveted to the frame that the bed bolts to. They have to be from a 4x4 frame.
Joe are these the ones you need?
Yes sir that's what I need. As long as that is a 4x4 frame they should work.
Do you have the front core support/leaf spring mounts?
No they were bad |
Hi, in the post #5 the crossmember between the frame rails. Condition and price? Ok Thanks
Junk. The frame was badly rotted there.
I would be interested in the 4 bed mounting "stands" also
Joe PM sent
ok everything is shipped so far. ttt who needs some frame parts.
Will take the 4 speed crossmember if it's still available.
frame horns still available?
Yes they are still available not perfect there is some pitting behind where the spring mount was but still strong and very usable.
PM on its way
If the frame is a 67, I'd would be interested in the spring hangers
Pm sent
Good morning BRP, any word on those frame horns?
