Brake Question for S10 frame swap
Just had a question about my build and figured if I was ever to get a answer this would be the place. I'm using a 85 S10 and want to do the blazer big brake conversion. I'm going to use a drop spindle, Hub/bearing, rotor and calipers from the 98-05 blazer set up.
Question is the inlets on the calipers are in different positions. Can I still use the stock S10 flex hose set up? Will the line reach? |
Re: Brake Question for S10 frame swap
for the trucks: the hoses changed in 91, and again in 98. the calipers are also different, I think they changed in 88. the difference in the 90 to 91 lines was only where the flex hose mounts on the frame side. the 90 uses a threaded mount in a round hole, the 91 uses a hex mount in a 6 pointed hole with a clip. I do not know what the older caliper/hose looks like because I try to stick to newer donors with the 4.3.
The 98+ blazer hose WILL NOT FIT the S10 truck hardlines, it is a different fitting size, unless you cut the hardline and put the larger blazer fitting on. I have done the swap with a 98 and a 99 s10 truck to 98+ blazer brakes. on one I needed longer hoses (ONLY because I used longer control arms) and I used hoses from a 88-98 chevy fullsize. in both cases before I used longer control arms the s10 truck hoses bolted right to the blazer calipers, just flipped. no issues with length. but for an 85, you may have to just try it. it might be possible to switch to 98+ s10 truck hoses and mounts, which as stated above work. you would need a pair of the hex frame mounts mentioned above and a couple clips. |
I've fought that before/after thing on brakes on GM rigs when I was doing brakes every day back years ago. That was on stock rigs.
So will the 98 s10 mount work on the 85 frame? Or do you need to modify or just easier to build new. Easiest way to do this would get a 98 s10 complete fuel line kit? |
you shouldnt need a brake line kit (I knew what you meant), just buy the hoses and the hose mounts from a salvage and they should bolt right to the hardlines you have. if you were going to change hardlines, just buy 98+ blazer hardlines and get 98+ blazer hoses. |
