Trans crossmember
I have a 86 c20 I’m doing a swap in with a 4L60E and was wondering if I needed to move my trans crossmember bracket? Or could I keep it in the same place? Thanks for the help
Re: Trans crossmember
Hard to know 100% since that will depend on what mounts your using etc. The xmembers are pretty easy to relocate, most of the ones I've worked with just had to redrill holes and bolt back into place.
Thank you, I just wanted to make sure before I got to deep into it
