LS various parts, garage sale
various LS parts here for sale. Garage sale of sorts for stuff I no longer need.
I take paypal will also be at the spring Carlisle show so meetup to avoid shipping is available. pictures are out of order, sorry. 1. Fbody 1 3/4 headers, Pacesetter ceramic coated. These fit 67-72 trucks fairly well, passenger side fits w/ no mods. Driver side may need small notch depending on how you mount the engine. The collector angle is off a bit, my plan if using these was to weld a bubble type flange on and connect up the exhaust. $220 shipped make offers. not wild about shipping these so for a local deal I can do much better 2. DBW truck throttle body little dinged up front lip. believe this was off a gen IV 5.3 $50 shipped 3. gen III front cover. black painted...new seal installed. installed but never run $50 shipped 4. water pump, believe this was gen IV 5.3 - no idea on the # of miles but looks low $50 shipped 5. starter, labeled 2000 gmc 5.3L . This was purchased from a junkyard...I never used it. looks in good shape $60 shipped 6. windage tray and oil pickup for truck pan. from 5.3 engine. $40 shipped http://67-72chevytrucks.com/vboard/p...ictureid=24494 http://67-72chevytrucks.com/vboard/p...ictureid=24495 http://67-72chevytrucks.com/vboard/p...ictureid=24480 http://67-72chevytrucks.com/vboard/p...ictureid=24484 http://67-72chevytrucks.com/vboard/p...ictureid=24482 http://67-72chevytrucks.com/vboard/p...ictureid=24483 http://67-72chevytrucks.com/vboard/p...ictureid=24489 http://67-72chevytrucks.com/vboard/p...ictureid=24488 |
Re: LS various parts, garage sale
MSD 6010 kit, with Edelbrock Performer RPM dual plane intake (cathedral port)
(for 24x crank) this stuff was purchased new quite a few years ago...never installed. This is similar to the Edelbrock complete kit that lists for $1000+. The MSD at at the time I purchased over the Edelbrock ignition module, because it had programmable timing curves. I'm sure things have changed since I purchased it...so I don't really know what this is worth. I'll throw out $650 shipped for all will separate if not interested in intake/ign together http://67-72chevytrucks.com/vboard/p...ictureid=24486 http://67-72chevytrucks.com/vboard/p...ictureid=24485 http://67-72chevytrucks.com/vboard/p...ictureid=24487 |
TH400 convertor, meant to bolt to LS engines
it has an extended snout that fits the LS crank 3500 stall, mfg is Midwest Convertor $225 shipped flexplate and spacer, with bolts $100 shipped http://67-72chevytrucks.com/vboard/p...ictureid=24479 http://67-72chevytrucks.com/vboard/p...ictureid=24490 |
