Quick question for ignition wiring gurus
My first time installing a complete wiring harness and I’m a little stuck. I’m putting a AAW classic update harness into a truck with a pertronix igniter unit in the distributor. The instructions say to run the pink wire (12v) to the positive side of the distributor cap. I’m assuming I just run it to the + side of the coil and hook up the red wire from the pertronix to the + coil also?
Re: Quick question for ignition wiring gurus
That sounds correct. There's an obvious typo as there is no wire connection to the distributor cap. Depending on what Pertronix unit you have it may want 12 volts or 6 volts.
Sounds like instructions for a H.E.I.
Here's a link of the instructions. I talked to AAW and they said the harness will work wit the Pertronix unit as long as it is straight ignition 12 volts which Pertrnix verified and said no resistor is needed.
https://www.americanautowire.com/PDF...20IN%201.0.pdf |
Anyone have thoughts on this? I don’t want to fry anything if I hook it up wrong...
Anyone?
Personally I would eliminate the Pertronix unit and go with the HEI. I feel the HEI is a more reliable unit
I'm running a Pertronix Ingnitor III module because I wanted to run a stock body distributor cap. I'm using an M&H harness that I ordered custom without a resistor wire.
Presuming you have eliminated your resistor wire or have otherwise provided an unmodified 12V ignition path, just follow the hookup instructions and all will be fine. If you have a tach you might notice it reads high at low RPM due to the multiple spark feature. |
The HEI will fit in a 4wd unless your body mounts are trashed. I just installed one in a 72 K5 for a customer. I can get my finger tips behind the cap. It's tight but it clears.
Your wiring is correct. 12v to coil +. Pertronix connects there as well.
I know guys have had issues with pertronix but i personally have one in a chevelle- going on 3rd season with no issues. And when I was a kid my dad installed one in a gto when they first were the hot item, that was probably mid to late 90s and it’s still going strong |
OK thanks for the help guys. I'm not too worried about performance since it won't be on the road all that often. I just want to keep the stock look because that's the look I prefer
I think the GM HEI is a nice reliable unit. The Chinese HEIs not so much. But it doesn't help him or me because we both want stock-bodied Delco style distributors.
Pertronix offers a ready-to-run Delco small cap distributor and I bought that for my truck, but on my current car restoration I'm using the module so I can keep the original date coded distributor. |
