1966 SWB Step Rear Brake ID
Just finished up replacing rotors, calipers, lines etc on the front brakes which a PO had upgraded to 70's era 5-lug disks. Got parts for a '77 and they worked just fine.
Now I'm getting started on the drums in the rear which look like they've also been swapped at some point to 5-lugs. I don't know if the PO used parts from the same source as the front or not, so I'm looking for advice on what parts I need to be looking for to do a rebuild on the hardware. The markings on the front of the drums are: 3989541 MAX DIA 11.09 A search for that number pulls up an eBay listing for 67-72 CHEVY TRUCK NOS Rear Brake Drums 3989541. Since that's the only result, besides a posting here about mismatching drums on a '71, I wanted to see if anyone has any further info on these. Here are some pictures: https://imgur.com/5K4aBlR.jpg 5-lug drum on rear-end. https://imgur.com/Mvf8RhQ.jpg Markings on 5-lug drum on rear-end, "3989541". Also has marked, "MAX DIA 11.09" https://imgur.com/c9bzc8b.jpg 5-lug drum heat side heat sinks on rear-end. https://imgur.com/zG1FIHD.jpg Inner plate on rear drums. https://imgur.com/aFZAfRc.jpg Upper inner plate on rear drums. https://imgur.com/dpo7N3C.jpg Lower inner plate on rear drums. https://imgur.com/chx7wZ8.jpg Brake pads in rear drums. https://imgur.com/QmfwusC.jpg Inner hardware on rear drums (1). https://imgur.com/dKKe6Sl.jpg Inner hardware on rear drums (2). Thanks. |
Re: 1966 SWB Step Rear Brake ID
Those are just standard 2" rear drum brakes. I've done this a number of times. Most of if not all of the parts are the same for many years.
I used 1977 c-10 11" x 2" rear drum brakes for the parts. Part numbers from Rock Auto. Drums: RAYBESTOS 2065R {#102065, 2065, F2065} Professional Grade; Outside Diameter 13.64" / 5 Bolts / Finned, Rear; w/ 11" X 2" Brakes Shoes: RAYBESTOS 449PG {#449NR, 449RR} Professional Grade; Organic; 11.00 X 2.00, Rear; w/ 11" X 2" Brakes Wheel Cylinders: RAYBESTOS WC37080 {#2037080} Professional Grade, Rear; w/ 11" X 2" Brakes Hardware Kit: CARLSON H7046 Drum All-In-One Kit, Rear; 473 OR: CARLSON H2324 Pro Kit, Rear; 473 Pretty straight forward. |
Excellent. Thanks aggie91 for the info. That's going to make it a lot easier.
