Defective lifters from Edelbrock
Hi all,
I'm halfway through putting an Edelbrock top end on my 454 (kit #2095) and I noticed one of the supplied lifters has a pinhole in the side. Almost like an oil hole, but only one lifter has it so I'm guessing it's a defect that somehow made it through QC. I know I should wait until I get a new set shipped to me, but it's a back ordered part so who knows when it will actually show up. Could be months...So my question is, am I out of my mind to use that lifter despite the blemish in it's side? |
Re: Defective lifters from Edelbrock
Do you really want to break the cam in twice? Because that's what you will have to do, for the lobe getting the new lifter.
i had a complete set of lifters and cam that had what looked like air bubbles in the castings that somehow made it through quality control edelbrock is junk don't trust them .
You purchased them in good faith that you were getting a quality product. You shouldn't be having to wait for a back order to move forward with your life. Especially for a common item like a Chevy lifter. I would be returning the whole set and going with a different brand.
The fact that Chevy V8 lifters are back ordered is a bad sign. Perhaps they have had a whole production run that is bad and are scrambling to make replacements. You may get just someone else's returned lifter, just to get you off their back. In addition if the cam goes south during break in you only get a cam and lifter replaced under warranty. The rest of the damage is on you. That means new bearings and possibly rehoneing or worst case a new bore and new pistons. Not fun and very aggravating. |
If you haven't already installed it, send it back so that E-brock can give other people with defective lifters their replacements sooner, and buy something else that is good. Win-win! :lol:
Comp cam.
All very good points. I've been in contact with Summit several times and they tell me that Edelbrock has processed my request for a new set shipped to my house. Now I'm just waiting for verification that it shipped. If I don't hear anything by Thursday afternoon I'm supposed to give Summit a call.
Here's a pic of the worst lifter. What do you think? |
It's not in a stressful enough position to be a serious threat. But in general, a pit can have a sharp edge, and as the engine cycles in temperature, a crack can propagate through the metal. Eventually the lifter could crack. Not saying definitely would, just that it could. I wouldn't run it except in a vehicle that I didn't plan on keeping a long time.
Bad QC!
Bill |
Then I had several of their stamped rocker arms crack and break (thought I broke a valve). Found cracks starting in several more of them on inspection. Upgraded to a better quality rocker arm from them too. Lesson I learned was the low end comp cam parts are JUNK. On my LS build I bought a set of $$$ Morel lifters. The outsides of the bodies were covered in machining marks/scratches like they were completely missed in QC. They went back (vendor accepted them back without issue after he saw the pictures) and I replaced them with a high end GM lifter. |
I know it looks innocuous but you don't know what piece of debris is waiting to come out of that hole and start scraping away at the lifter bore. I know, again with the worst case scenerio.
There's so very much information and so many folks here, it's difficult to get a feel for who knows what, and why...
ALL, ALL the cam companies use import lesser expensive lifters. No one should EVER use cam company lifters..period... Hylift-Johnson are the only American made lifters. They are far and away the very best lifters made, nothing close. 1-800-441-1400. There's likely nothing wrong with your lifter with a pit in it, but it's an indication of the overall quality, which is not good... I'd see if you could send back ALL your lifters for a credit, buy the Hylift Johnson's. Hylift Johnson has a website. BEWARE there is another lifter company called Johnson Lifters, NOT the same as Hylift Johnson. |
I just had 2 Lunati lifters and 2 summit pushrods fail in my last rebuild. I swore to myself I would not use anything but Delphi (GM/Hylift Johnson) lifters in the future and Crower pushrods. So, my last build on the top end came out as follows:
Lunati Cam(Flat Tappet), Dephi lifters (Hylift Johnson), cower pushrods, Harland Sharp rockers, AFR Heads with springs replaced to match Cam specs. No issues... |
Comp Cams is a sister company to F.A.S.T. - Fuel Air Spark Technology. I can tell you this about FAST and their customer service. This company must be owned by Barack Obama and Hillary Clinton. Every problem with their product and lousy customer service is the fault of George Bush and the Russians. They will place blame instead of standing behind their product.
Stay away! |
The good news is that Edelbrock has shipped me a new set. Unfortunately they are coming from the other side of the country and were shipped snail mail, so it will be here on Monday at the earliest. In my mind they should air mail it for free since it was their screw up but...whatever. It probably won't hold me up since I have plenty to do in the mean time, but it's still irritating.
