LS Tach Signal to 2 Devices
Is it possible to use the same tach signal from the ECM to feed the pulse signal to 2 devices. I have it running to the Dakota Digital box for the gauges - but would also would like to run the optional tach pulse signal to my Innovate Boost Controller.
Any issues feeding both from the same source? |
Re: LS Tach Signal to 2 Devices
Shouldn't be any issues running the signal in parallel to two devices, neither of them is going to pull any significant current.
Yes. I have the same Dakota digital box and I drive my fuel pump controller, tach, and so on all off the same tach signal wire.
Perfect. Appreciate the responses.
