Looking for a rear mount tank
Hey I'm looking for a rear tank, preferably EFI ready, and definitely as bolt-in as possible. I see No Limit makes one, and CPP does too. Does anyone have any experience with either one of those? Is there anyone else I should look at? Thanks.
Re: Looking for a rear mount tank (NOT BOYD WELDING)
A lot of us use an OEM Blazer or Suburban tank. Although this may not be as fancy as the other options you are looking at, but it gets the job done.
GSI Machine Fab just started making these for c10’s.
I’ve got a bad blazer frame I’ll remove the tank crossmembers and mounting hardware from if anyone is interested.
The drawback to the Blazer tank is no baffles. When mine shows less that 1/4 tank (about 8 gallons) and I corner and throttle hard, it can loose fuel for a second.
3 Attachment(s)
I got a poly 31 gallon Blazer tank from here http://www.ineedparts.com/heavy-duty...y-gm-en-2.html
It is baffled. |
Why not Boyds? Ive used a few of them and always had great luck with them.
Boyd fuel tanks are pretty sweet, you can always go to EFI for when your ready to go that routeAttachment 1785822
