Grease gun accessories.
The rear ujoint on my 02 Silverado is a pain to grease.Does anyone here have any thing they use to get in there and grease it.
Re: Grease gun accessories.
https://shop.advanceautoparts.com/p/...source=bing&ut
I have used this on different applications. It helps if you have three hands :lol: or someone to help operate the gun while you try to depress the ball and spring. |
I got one and it actually worked on greasing the ujoint on my Silverado.
I used a grease needle also. It's a bit PITA to use but it works.
different uses but they also make a slide on 90* head for tight spots .
but the needle type adapter shown above is the ticket to u-joint greasing jobs . and when changing u-joints try and plan ahead on zerk fitting position . i set them up so there facing the drive shaft tube NOT the axle u-joint yoke . and also clock them to match so you dont need to roll the shaft to hit the next one . |
