Lowering my c20
2 Attachment(s)
Ok ive searched and either missed it or didn't look long enough (adhd). Im looking to lower my c20 about 4-5 inches in the rear, and about 2 inches in front. I have 16" wheels and stock 31" tires currently. Im eventually going to a 20" rim and about a 30" tire. For now, can I take any leafs out to lower it a couple inches in the rear? And ive read about cutting front coils by 1 coil safely. How much drop could I get cutting 1 coil up front, and taking the overload leaf and however many others safely in the rear? I wont be using the truck to haul more than a light boat and an atv (2000 lbs. Max at a time).
If there is a specific thread or build on here please link me to it. EDIT** Im just wanting to do a budget type drop until I get my new wheels. Then, I will be going normal route and getting new suspension. |
Re: Lowering my c20
I took two out of the rear dropped about 1 1/2 But you need to shim the u bolt nuts to clamp the rear tight. Mine bottomed out before they were tight. Haven't done the front yet but I'm going to use drop spindles. And then 2 inch lowering shackles in the rear.
Re: Lowering my c20
2 Attachment(s)
It'll look sweet once you do the full rebuild. I'm still working on it, but this is the stance on ours. lots to do yet. 1972 Custom Deluxe 20 Custom Camper.
Re: Lowering my c20
how much did you drop yours pepper??
Re: Lowering my c20
2 Attachment(s)
Re: Lowering my c20
...actually now that I look at it, it looks like yours might be just on top of the tires? Its kinda dark around the tires in the pic. |
Re: Lowering my c20
Re: Lowering my c20
Re: Lowering my c20
Re: Lowering my c20
Re: Lowering my c20
Re: Lowering my c20
5 Attachment(s)
Re: Lowering my c20
5 Attachment(s)
Re: Lowering my c20
Re: Lowering my c20
Re: Lowering my c20
Here's mine. I have coils in the back. Lowered 3.5 upfront with drop spindle and 1 inch drop spring and 5.5 in back with 4 inch drop spring and 1.5 inch block. No c notch. Haven't loaded it much besides helping friends move and furniture pickups. No problems with clearance. Want to lower more in the back but the rear end pumpkin is close to hitting. I have 20x9 Detroit steel wheels on it
Re: Lowering my c20
2 Attachment(s)
Sorry forgot pictures. Lol.
Re: Lowering my c20
Re: Lowering my c20
5 Attachment(s)
We couldn't find a flip kit for a C20 with the Dana 60, so we got one that would fit a 3 1/8 Dia. housing and went from there. Here's the pics of the mods we made. You can see that they were a little to wide and to short. But a little fabrication and some TIG welding, and they work just fine.
Re: Lowering my c20
Pepper, what kit did you start with? That seems like such a simple kit.
Re: Lowering my c20
4 Attachment(s)
It was a kit from Western Chassis that fit the dia. of my Dana 60 which is 3 1/8 in. The location holes are larger than the head of the spring tie bolt, so I had to make adapters to locate the axle.
Re: Lowering my c20
Re: Lowering my c20
Re: Lowering my c20
