Closed knuckle shaft won’t come out
66 K20. I’m not sure what I can be doing wrong here. It clearly will not fit through the hole
Re: Closed knuckle shaft won’t come out
Do you have a service manual, if not, will look up for you.
Will take photo of instruction and post. Les |
I did this about a year ago and don't remember this problem. A couple of questions;
Are the wheels in the straight ahead direction? They look turned in your pictures, and I don't think axles will come out if turned. Is that an HD or regular 44? Looks different than mine, but might just be angle of picture. |
I've got one and according to it, it should pull right out now. I've found from searching online that apparently that's not the case with the d44hdf, you have to split the knuckle to remove the axle shafts. Thanks for your offer though. |
Glad you figured it out, and able to share solution. |
