71 GMC big block parts
5 Attachment(s)
Heat Shield, Air Cleaner Spacer. Still available
Re: 71 GMC big block parts
5 Attachment(s)
pics
4 Attachment(s)
more
5 Attachment(s)
Big block pulleys. The double pulley is also used on small block A/C applications. The set off of the big block, 1 single one double, has some pitting. $20.00 plus shipping for the set. The super clean double $15.00 plush shipping
4 Attachment(s)
more
Great prices! Wish I needed this stuff.
2 Attachment(s)
1971 gas pedal and bracket . Nice and clean. Two piece pedal bracket for kick down switch.
Will include some of the kick down switch parts. The plastic slide fell apart. Also have the wiring that was there. $30.00 US plus Shipping |
2 Attachment(s)
Big Block exhaust heat shield. Really Nice. With bolts.
$40.00 US plus shipping. |
2 Attachment(s)
Carb Spacer. Cleanest I've ever seen. Zinc is nice and bright. There is some minor oxidation.
$15.00 US plus Shipping. I have the air cleaner and lid too but its dirty and has surface rust. Pics on Request. |
I have a few more bits I'll post after I clean them up. I have the Brake booster connection hard and soft line with booster fitting. I have the brake booster firewall braces as well.
I`ll take the big block power steering , pulleys , and the gas pedal .
shipping to Elberton ga 30635. thanks , Woody |
Posted via Mobile Device |
I'll take carb spacer. Let me know shipping to 87107. Do you have stove pipe setup? Or any part of it?
No stove pipe. Need a city/state a zip code only won’t get me a shipping quote up here.
All of the pulleys? Both of the two groove?
All 3 pulleys. The pitted pair, and the nice double.
It’ll be tomorrow before I get to town for a shipping quote.
Is Albuquerque New Mexico 87107
4 Attachment(s)
I also have this alternator bracket. It came from the same truck. I’m not overly familiar with big block stuff. I assume it’s correct. It’s had a tab repaired or modified. I’m sure it can be restored with a little effort. 15 bucks plus shipping
I'll take the alternator bracket also
do you have the cast lower bracket for the alt ?
No I suspect that went with the alternator. Wasn’t there.
The brake vacuum line is cleaning up nice. There is also a Th400 shift bracket on the frame I might be able to get. It looks different than the small block ones I’m familiar with. |
Heat shield and air cleaner spacer still available. With a pending Canada Post strike shipping could be an issue. UPS is very expensive. In general shipping to locations outside of Canada is more than most down south are going to expect. The border between us adds a lot of expense.
Sorry to pass but shipping is as much or more than part. Good luck with sale. Maybe they think is Mexico and two borders to cross. Lol. Good luck with sale.
No worries
