Where does Red Wires go? 04 Sierra
2 Attachment(s)
Where do these 2 wires go from around my fuse box area on the driver side I remove my left fender and fuse box and putting new fender on now I can’t remember where these two red wires with terminals go. please see picture. Any help is much appreciated thanks |
Re: Where does Red Wires go? 04 Sierra
I tell my son to take photo before he disassembles his vehicle for obvious reasons. I don't need more to do...Is my answer.
Until I get my screen to quit going black on second laptop of 3, that now doesn't work, I would use GM eSI to tell you, but one is hot from the battery/engine red block and goes on the terminals post closest to the headlight. The other is hot with the key on, engine off, and goes on the right side terminal post closest to the windshield. It probably won't work until the battery wire is hooked up first. One half of the under-hood fuse/relay center, while the other half is hot with the key. But, considering the time since this was posted, I would hope you got it fixed and just did not tell us. I did a head gasket on a Renault Fuego. Coolant hoses everywhere. In the same day going back together, I felt the hoses would fall back into place. They didn't. I drove to a used car lot with a pad of paper and pen, drew a picture, fixed the car and never worked on one again. The Lancia-Bata was much easier. Hope you got it going. |
