1965 swb chevy c10
Time to sell my 65, It has a 350 that has been freshen up with new rings and bearings and new gaskets hei distributor, holley 600 carb. It has a 3 speed transmission. New clutch,pressure plate, throw out bearing and flywheel. The interior has all new paint, carpet,seat cover,wiring harness and turn signal switch,gas tank and sending unit.90 percent of the body work has been done with 3 coats of epoxy primer, new cab corners,inner and outer rockers. Windshield is new, cab mounts,all brake lines rubber and metal, brakes, wheel cylinders, drums have been turned. Brand new tires, battery,radiator,hoses,ujoints,ball joints. It has duel exhaust with 40 flowmasters. Sounds great. Runs and drives great.The wood in the bed is rustic oak, with new strips and all new bolts.. The weather stripping around all the glass is also new. There is a lot more. I went with the flat black with 60 series tires for the old school look. I have receipts and lots of pictures. I have a clear title in my name. Wanting 14000. Drive it home
Re: 1965 swb chevy c10
Do you have another project? I know it’s hard letting them go! Good luck with the sale!!
Yes needing the room. I am having a blast driving the 65 it is a lot of fun
12500 need it gone
make offer
Show us some pictures of it .
Click on the link above and there is all kinds of pictures of it My second and third post the top link
Can you guys see my pictures?
Yes. Nice truck.
Ok good. Someone on here said they did not see any pictures so I emailed him some but he did not let me know one way or the other if he could see the new pictures I posted on the forum
Pictures on the forum are good!!
Sold
