seat belt question. help plzzz
can anyone tell me if a 1986 k10 seatbelt as in pic fit a 86 k5 blazer? are they interchangeable?
i thank you in advance. dave |
Re: seat belt question. help plzzz
2 Attachment(s)
pics of k10 belts
thru further investigation i found these on ebay wrong color and noticed the difference in shape. so maby blazer is all alone?
They will 100% NOT fit.
Truck belts bolt to the floor and Blazer/Jimmy bolt to the lower B pillar. Full size Blazer/Jimmy are there own design. There is no cross reference seat belt for them from any other GM truck or car. That being said, the LH and RH retractors will interchange with some internal work. That's another story though. Anything pre '89 will bolt in with female floor ends you have. Back to '78 if I remember correctly. After 1989/early '90 is late 90-91 only. GM switched suppliers and they are different. You would need the 90-91 female ends as well to make it work. They have the orange release button vs GM plastic buckle. 90-91 belts also did away with the retractor plunger on the door jamb. It was biggest problem with those belts. Get full of dirt and stop retracting. |
WOW Irish, You my friend are a Warehouse of information!! I Really appreciate your response!! so now to find a set from an 81-87. as my tub is a 86.......... A G A I N .... I THANK YOU for taking the time to educate me on the belts. i owe ya one. dave |
