Lower Kits
I was suprised to find out that Bell Tech doesn't do a lowering kit for my 72 C10. Any suggestions on the best kits out there? Thanks
Re: Lower Kits
Re: Lower Kits
Front and rear sway bars are a nice addition as well
Re: Lower Kits
I used early classic dropped spindle disc brake kit for my truck and am very happy with it. And sway bar too.
Re: Lower Kits
Early Classic Enterprises as the previous posters all suggest.
Re: Lower Kits
What they said! 2/4 drop on my 72 with shock relocate kit and adjustable panhard bar. Awesome. All ECE.
Re: Lower Kits
I am new to all of this lowering kits and disc brake conversations, but do need to make a front disc brake conversion and lower it a bit as well maybe 2 inches max. on my truck that purchased back in august.
The disc brake conversion kits on ECE, when it says with 2.5" drop does that mean that kit will allow me to further drop the truck by 2.5" or this is for a dropped truck with a 2.5" drop? Do I need a separate lowering kit as well? As mentioned I am completely new to all of this and learning quiet a lot form all of you on this website. |
Re: Lower Kits
I have used classic performance. I had good luck with their kit. I used a complete drop spindle, 5 lug and disc brake conversion kit. Everything bolted right up, and I had no issues at all.
Re: Lower Kits
I have the ECE disc conversion 2 1/2” drop spindles on my 69 short step. Along with a set of 2” drop springs and the sway bar brackets for a lowered truck. I used DJM parts in the rear for a leaf spring flip since ECE doesn’t make that solution or I would have used all ECE parts. |
Re: Lower Kits
Re: Lower Kits
Thanks for all the replies. Time to get on it.
Re: Lower Kits
Re: Lower Kits
Did you all buy direct or go through a supplier
Re: Lower Kits
Re: Lower Kits
ECE is the best imho in this dept....you can't go wrong with these guys....cheaper maybe but they are the best resource.
Re: Lower Kits
Thanks Again
Re: Lower Kits
Re: Lower Kits
I will pile on... ECE drop spindles/springs ++ ECE drop springs/blocks and panhard and shock relocation in the rear. While you're at it, spring for the front and rear sway bar kits as well. These things will make your truck stay much more level in the turns but the most benefit of all is that it calms the thing down at speed going down the road over irregularities. The difference is amazing! -klb |
Re: Lower Kits
Thanks Again to all! Going to spend a few months in FL. and hope to meet and talk to some truck guys dowm there.
Re: Lower Kits
Really? Because they have a lowering kit for my 72 C10... As well as every other 72 C10 out there....
They don't have the performance handling drop kits, but they do have drop kits. |
Re: Lower Kits
Re: Lower Kits
OK I guess I got some bad info,I've used their products before and really liked them. I'll get their phone or email and get in touch with them. Thanks again.
