C H E V R O L E T hood letter template needed
Does anybody have one of know of someone who does?
Re: C H E V R O L E T hood letter template needed
Like the letters in my avatar?
Here are a couple links that may help:
Post 12 http://67-72chevytrucks.com/vboard/s...d.php?t=329097 Template http://67-72chevytrucks.com/vboard/s...d.php?t=647842 |
4 Attachment(s)
Randy
What do you think? I still need to fine tune this Jig. Working with this Today enlightened me to other options. Attachment 1844385 The First E (In the pic Above) is just push in but not clamped or bolted down. The E's are Different. L &R Learned something Today. Attachment 1844389 I had a Great Helper Today :lol: Attachment 1844390 The Gold hairy thing in the Picture is Our Puppy. My new addition to the family. Attachment 1844391 |
Is that coated aluminum? If so can you trim the left side to match the hood peak for lining it up. Or do you set up the right side first, drilling the holes for the R on both sides and locate off the left R stud.
Whats the closest drill bit size, i will order a few bits.
Actually it is steel sheet metal.
I had first planned aluminum and a lot more detail . Yes the right side is the set up. This locates the Most important/ R that is in the middle. The Twist drills required are #24 (0.152) & #29 (0.136) The right has scribe mark for alignment. The left needed trimming for the (relief) to match. That is just the Ruff phase. I got 1 more Trick I hope to get this tweeked this week. Number 24 drill for big holes on left and number 29 for locating holes on the right. |
Ok, looks good and sounds like you got a good plan there.
Randy
I am making good Progress on the Jig. Do you have the hood and new letters? I got a couple of new pics of the jig . |
I’m putting the Chevrolet letters on my current 68 gmc hood, I didn’t order the letters yet, probably will do that this week.
Randy
I hope to ship that jig Monday. I tried a few other options at a couple other templates. I will get them Fine tuned this weekend. Dwayne |
Sounds good. Send me your paypal and i will send the money.
Randy
I will pm you with all the info and stuff . I was wondering with you using your GMC hood Do you need the template for the big holes in back to install the nuts? Or will you drill thru and then drill the holes bigger? Dwayne |
2 Attachment(s)
Randy
Can you work with this in the pics. Below? I will work on the box to Ship it this weekend. No Instructions Included :lol: You built a Tough Looking Crew cab. So I know you got this. Attachment 1845813 Attachment 1845814 |
Pm sent
Package is on the way.
Thursday is projected day of arrival. |
Thanks buddy, ordered the letters too, they should be here saturday or so
Template received and my hood letters arrived. Havent had a chance to order drill bits but will soon, thanks Getter-Done!
Your Welcome
From my experience working at a tool and die shop and working with stamping dies for several years. I noticed something about the alignment. If you get the holes drilled correctly, the Top of the letters will line up 2 inches above the crease line that is closest to the letters. If you notice the tape I left on it. A 2 inch piece of clear tape aligned with the bottom crease. The 1 inch piece of tape even with the top of the 2 inch tape. |
Is this template for rent ?
If it meets Randy's approval for ease of use and quality. I am working with the Post Office about the most economical way to ship. Thanks for the Interest. |
