Wanted: automatic transmission linkage
I need the shift leaver and the bellcrank. The shift lever I have is not original, looks like it's out of a Chevelle from what I've seen on the internet. And bellcrank is original but the holes were attachs to the shift lever looks like they're enlarged due to wear. I was able to find a shift lever online a reproduction but would prefer original stuff. Anybody has any leads I'd appreciate it. Also need spring on pivot. Thanks.
Re: Wanted: automatic transmission linkage
I might have part of it
I have all of it!...Trade for right front bumper bracket!
Pictures
More
I need a picture of The notches, not the holes it's where the Shift lever fits in as in the picture above. Your first picture shows half what I'm talkin about
It's in a little bit better condition than mine but you can see that notch when you look at the picture on the left has a little wear. Mine is more exaggerated than that. I think I'm just going to weld then cut it out again. Thanks so much
I can take a look thru my box of them if you are still looking
I'm going to wait for the shift lever to come in and then just install it with the existing bellcrank. If that proves to be a problem I'm going to take the bellcrank off weld two notches shut and cut new notches. And if that fails I'll be reaching out to everybody again. Thanks for getting back to me.
