air ride manifold mounted inside?
I have airlift 3p for my truck. It seems like a lot of people mount them under the bed where you cant access them unless your bed floor lifts up. I thought about mounting it inside with the ports facing down and shoot the airlines straight down thru the floor. The only downside I can see is id have 6 holes in the floor now. But the manifold would be protected from the elements.
Re: air ride manifold mounted inside?
I had the manifold behind the seat in my 65 worked just fine. I also had the compressor back there.
Jimmy |
I have the tank,comp and valves all in my blazer behind the seat, might move the tank under if I can find room but all I have to do is unhook a couple lines and the whole assembly comes out in one piece
Do you guys have all the lines going thru individual grommets, one big grommet or bulkhead fittings?
