WTB rear seat rear brackets
Looking for back brackets for a rear bench on a 72 blazer I believe it was only a pair. Also if anyone would know do the rear brackets fit from 73 up Blazers? Thanks
Re: WTB rear seat rear brackets
73 up are different
I wasn't aware of it but I believe I need ones around 4- 4 1/2 in tall
Square body does not use the front tubular brackets. All 4 brackets are stamped steel (similar to the rear on 1st gen) and do not line up with the floor ribs. I will take a look to see if I have an extra set but I think I am out of them. Hard to come by anymore and expensive when they are available. the brackets from 67-72 suburban 3rd row is also the same as what you need. 2nd row will not work.
Ok, Thanks for looking let me know if you come across any.
I was actually the first one to bid on them but now holding off till the end to see what the damage will be if I want them.
Nice. It looks like they come with a little rust. If they were pristine I’d feel better bidding high.
