1970 gauge cluster issues
I'm having issues getting power to my gauge cluster I checked my fused panel everything is getting power except for the upper right side for my cluster feed on the back of the fuse panel I am not getting power from the dark green wire not the grey wire where do these wires go? My blinkers work and getting power to a couple of other terminals on my cluster I believe it's the 2 black wires number 1 and 12 I believe 😖
Re: 1970 gauge cluster issues
Welcome Aboard the forum!
If you use the search box above and click the 67-72 button you will find dozens of threads on your problem. Lots of information and no waiting for a response. Good luck! |
