Dash lamps for 69 truck
Would like to hear your suggestions for dash lamps. RockAuto shows the following, among several others:
Wagner #1445 -- 1.94 watts Wagner #1816 -- 4.29 watts They also list LL (long life) versions of the above with the same wattage specs. Obvious I'd want the higher wattage bulbs, but are those specs correct? FYI, AC-Delco has a L1445, but they don't show wattage. Also, I want to get a few bulb sockets. Will I need both 1/2" and 5/8"? The truck is at my son's house 1500 miles away, so I can't pull the instrument panel to check it. |
Re: Dash lamps for 69 truck
Bump
The lamps are 194 wedge base lamps. If you like them brighter than standard, a 168 bulb is the brighter version.
Thanks. Same as my 82 truck.
1816 and 1455 must be the latest bulb numbers. Do you know if the sockets are 1/2" or 5/8" diameter? |
5/8 according to this listing
https://www.classicindustries.com/pr...ts/cx1807.html I don't think you can be 100% sure until you walk up to the truck. I have seen mention on this forum about people finding completely different bulb holders and bulbs in their truck's instrument cluster. |
I've got 15155, im thinking, in mine. They are pretty bright. also paint the cluster housing and the back of the black shield white or silver. I painted mine silver.
Thanks guys. I was able to reach under the dash and replace three 194 bulbs (one bad, two others probably on their last legs) with Sylvania 168LL bulbs. The last time I replaced a bulb in the truck was in the late 80s/early 90s, and some of those that I replaced this week may actually be original equipment!
The 168s are still not very bright, so next trip I may pull the panel and "brighten up" the inside of the bezel. I did something similar on my 82 truck. Instead of paint, I used aluminum HVAC tape. It made a noticeable difference. On a related note, just replacing the OE wiring harness, fuse panel, and most connectors on my 82 increased the voltage to the instrument panel by nearly 2 volts (!) under load. Same is true for the headlights, so no headlight relays are needed! |
I was wrong on numbers. They are 17177.
