How to flip seat back forward
Just picked up a new to me, 71 Cheyenne Super. Wondering how the seat back (bench seat) blips forward so i can access behind the seat area? Thanks in advance!
Re: How to flip seat back forward
They don't flip forward.
jbarron is correct.. The seat doesn't "flip" forward.. However, if you need to access the fuel gauge sending unit, you can remove the 4 (2 on each side) seat mounting bolts in the rear and loosen the front 4 bolts.. Tip the seat forward and place a block of wood under each rear "foot".. This will allow you to gain access to the sending unit without fully removing the seat... Replace and tighten the bolts when you are finished.. Don't drive the truck with loose or removed bolts..
I'm no expert, but my bench seat leans forward. I think there's some extensive discussion about this on the forum. I vaguely remember something about it changing based on year?
Either way, pulling the seat isn't very hard if you need to access that area. |
67-68 fold forward, 69-72 do not
Unsure if it’s correct for my truck as it’s how I got it 15 years ago. But my 70 appears to have angle adjusters that just had the lower lock nuts removed and now it flipped forward
That's a 67- early 68 flip seat Later 68 -72 bolted solid with the upholstery covering the arms . :chevy:
While we're on the subject then, what would make good fold-forward bench seat candidates for swapping into our rigs?
I know that I wish there were a couple more inches between me and the steering wheel; I'm always trying to push myself back. So a really thick, plush seat would make that worse for me. (and I don't have much of a beer belly either!) |
If you need more room between you and the steering wheel, collapse your intermediate shaft and bring the column closer to the dash. Changing a seat will not gain you any room. Once the seatback hits the cab, it isn’t moving back any further unless you angle it forward, making it uncomfortable and unable to lean back.
I've got my brake booster out right now anyway for some major re-wiring at the firewall........................"as long as I'm here"!! Anyone got pics of moving the neutral safety switch back? It looks pretty close to the firewall already! |
Can a non folding seat be made into a folding seat?
