Reassemble cab parts
I am now reassembling my cab interior.
Has anyone made a list of the order to put everything back in under dash ? Mine was total stripped before blasting and repaint . I know there’s an install order , I don’t want to do it more than once. |
Re: Reassemble cab parts
subscribed
I did this recently on my 72 Cheyenne that is a A.C. cab. There are some items that need to go in order or you are tearing it out again to get it right. Here is what I did from memory.
-brake pedal assembly -parking brake -windshield wiper motor -dash pad -items on dash like ignition, cig lighter -wiring harness -radio since it above the heater/AC controls -run any extra wires needed for speakers and or sub wiring -center AC outlet if you have AC -heater box assembly -AC/heater vent hoses - run them long out of the location they need to go -AC/Heater control panel -vacuum lines -door cabin switches in door jab if you have them -steering column - let hang down so you can attach oil line and plug in to dash bezel -dash bezel -glove box carboard inner -glove box door -kick panel vents -cabin light -install seats last it gives you room to work and have complete access to everything under the dash |
