'60-'62 Front Shock Bracket
In the past week or so, I have had 2 people email me and ask if I make a front upper shock bracket for the '60-'62 frames. Apparently when swapping the '73-'87 front suspension under a '60-'62 frame, there is an interference with the top of the shocks, the upper control arm shaft and the stock shock bracket. Not having done this to a '60-'62 frame, I am at a loss. I searched and did not find any mention of this issue here on the forum. Have members here experienced this issue? And is there a need for a shock bracket to correct this issue?
Re: '60-'62 Front Shock Bracket
For reference, CPT. From Porterbuilt kit on my 62
I think I'm on at least 4 years gone by and still haven't done my newer front end swap on my 62 frame. :(
I got a pic of a 57 chevy pickup with a Volare clip torsion bar with bags. Remind me I will dig up. The volare clip was done in 80s to do what my 62 did stock.
the stock location of the stock bracket is at the wrong angle for the late model x member n lca...I just moved the stock bracket on my frame..mine are just tacked in at the moment
I used a thin cut off wheel removed stock bracket and bolted it back on in new location.
That's what I did on my 1960 as well. I removed the stock bracket with a new Dremel cut off wheel, moved it back several inches until everything fit correctly, drilled new holes and bolted it back on with grade 8 bolts. It's been in place for over 10 years now working perfectly.
