1972 1/2 ton np205 front output seal ?
I will first apologize as i would have searched the forum/google for my answer but my phone is on its last leg and is being a pain to use. My front output is leaking like a our government spends our money....out of control. Does anyone happen to know the part number and if jts a pain to change??? Its an automatic truck if that makes a diffrence....
Re: 1972 1/2 ton np205 front output seal ?
https://torqueking.com/product/80044...t-output-seal/
To replace ..remove front driveshaft...remove nut inside yoke...remove yoke..remove seal housing...replace seal...then reverse procedure.... |
Oops...!!.....haha.....and oildry....
Thought you'd like that!-- of course I've never done that in a hurry.
Thanks guys.....got one ordered.
i buy a whole gasket /seal kit off ebay for around 25 bucks then i am covered for when ever the 205 leaks more than it should .
I would remove the hump also. The front shaft bolts are hard to access. I have a 465/205. I remove the hump for easy access. :chevy:
j |
