Lets see your Air Management Systems.
How did you set up your air tanks and compressors?
Are they accessible through the bed? Bed lifts? I want to see them all, good ideas and those that you regret for whatever reason. |
Re: Lets see your Air Management Systems.
2 Attachment(s)
Neatly tucked under the raised floor
Is it just a standard hinge? is the entire bed floor removable if you need to work on the system? |
The gas shock placement had to do with height on opening and smooth operation on closing.
The hinge system is the same as a hard tonneau cover, but modified slightly for my application. Yes, the floor is completely removable and I have used it as a picnic table once. One end stayed on the truck and I had two makeshift legs for the other side. I slid it out to where I needed it and had a good ol time at a truck meet. |
I wanted an air ride set up on big red, until I was quoted starting price of 9k in Australia
