Roof Rack for Suburban?
Anyone know of a roof rack for the Square Suburbans? Did they have one from the factory as an option? Were they sturdy?
I am outfitting mine as an Overlander for camping and exploring and I need a roof rack to mount a few things to. I sold my welder a few years back and don't have money for a good replacement so welding one up is out. I thought about using pipe, but I am afraid it would cost a lot and look like poo. I want to mount things like an Awning, water storage/shower, tire, my High-Lift jack, Light bar, etc. Any suggestions? |
Re: Roof Rack for Suburban?
I have one on a 1979 Parts Suburban
You should find a con-ferr rack. I actually have a few. They mount to the gutters but we’re discontinued maybe 15 years ago. Con-ferr conferr or con ferr on Craigslist. Run about $300-700 depending on length. Make sure it has mounts
I would still need to add some fake drip rail mounts like you see on canopies some times. |
So far it looks like I can build a rack from Aluminum Extrusion (8020) for about $600 and it be custom made for my needs. It will be all T slot extrusion and will give me a ton of modular capability for adding, attaching and changing things as needed. Now I just have to save up the money to do it.
I built crossbar racks for a canoe on my old Suburban out of scrap 1x2 oak that I got for free from the shop where I worked at the time.
I just cut out a couple good pieces about four feet long, plus four pieces about six inches long with ends cut 45* for spacers. I used four 1/4" carriage bolts for mounting and drilled through the layers of oak and through the roof at appropriate places on the raised ridges. It never leaked with the oak tightened down against the raised ridge on the sheet metal. It helped that I had no headliner anyway! |
I bought the Suburban and a 96 BMW R1100RT motorcycle this month and the registration fees alone have cost me $800. My current budget is in the negatives till I can either sell some stuff or something. |
I used the oak because I had it, and to not have metal on metal rubbing anywhere. The wood was a buffer between the roof and the aluminum canoe. The carriage bolt heads sucked down into the wood and I only had to tighten from the inside. After we traded off that Suburban for a 4x4 version, we saw the old one being driven around town still with the custom oak boat rack :) The other thing is that whatever you make it out of, think about having a couple of permanent simple rails (either crosswise or lengthwise) and then clamping/bolting whatever basket or box to that so you can easily take it off, but still have a secure mounting. |
I used Yakima on my old one....
Spacing could change a bit depending on your needs. Mine was driven for the fairing and the bike rack trays. |
I believe my truck has a factory roof rack. It's a 91 and my wife's parents bought the truck in 94. Sturdy I would say not, enough to mount one of those totes above it but that's about it.
I know this is a couple months old, but I was on CL and saw this ad for racks. Looks like they make them for just about everything. Prices look pretty good too. http://bajavoodoo.com/roof_racks Here's the CL ad... https://dallas.craigslist.org/dal/pt...008864850.html
Anyone own a 1979-1980 suburban factory 454? I need help and need a picture of the emission sticker diagram please. I need to pass smog. Thank you
Posted via Mobile Device |
Tomorrow ok? Its pitch black here........
Mine is federal, that one is Cali......
Looks like you are in Louisiana.....
Thanks for replying . But i won’t be able to make my c10 smog legal and the 454 will have to be removed since it was not an engine option for c10s. Cali is strict so I’ll be going back to finding a cheap 350 to put in and follow my smog diagram as original . Thank you
Man hate seeing this..you do know you can go back on guy who sold it to you for smog repairs. Small claims court(DMV is no help here) and you will likely not get any cash BUT DMV will make his life miserable. And if he title jumped it's even worse.
"The seller is required to provide the buyer with a valid smog inspection certification at the time of the sale or transfer. Smog certifications are good for 90 days from the date of issuance." SELLER is responsible for vehicle to pass smog. Cal law. |
