Need some advice from you guys on what size truck to buy
.I sold my duramax truck and travel trailer thinking I would not be using it any more and since then the wife is on much better medications for her Fibro and RA that has helped her a lot ,,so we are
getting back into camping and also taking the camper with us to California when visiting our son and wife and new grandson ,,we plan on staying a month while there ,,so want our own little home while there... With the durmax I could pull freight cars I believe but now I do not want a diesel rig ,,, I want something lighter for a truck . Whats your advice for a truck pulling this used travel trailer I have shown here We bought a 2017 Ultra Lite travel trailer last evening and it is a 23 foot (bumper to tongue measurments) 4471 lbs dry weight, hitch weight 507 libs with dual axles And now we need to buy a truck I do think that the newer trucks are beafier than the old one I had in 1973 ,,just not sure how much more What do think I should get to pull this trailer comfortably for hills to climb and hills to hold the trailer back to go down I am want to buy a 2014 used truck ..(within our price range) prefer a GMC 4 door short box Questions are this 1500 ? 2500? 1500 with a 5.3 liter gas or a 6.liter gas 2500 with a 5.3 liter gas or a 6.liter gas With or without 4/4.. if you think this has factor with the extra weight in the truck for maybe more controling of the weight of the trailer..?? I once had a 24 foot trailer years ago 1975 and it pushed me right out into the middle of a cross street when pulling it with my 1973 Chevy 350 ,, the trailer loaded was around 8000 lbs or more,, going to fast was the main problem .. but I think it was to small a truck also to handle the weight of the trailer.. my first trailer pull |
Re: Need some advice from you guys on what size truck to buy
I my opinion if you are purchasing primarily to pull that travel trailer I would go 2500 with the 6.0 liter. I had a 2013 5.3 1500 4x4 and now have a 2017 5.3 4x4. While I like both the trucks, if it were a more dedicated hauler I'd want something better designed for it.
I would suggest a 6.0 2500 extended cab with a long bed. I know it wasn't what you specified but that's my input.
I'll admit that I own a 4 door half-ton with the 5.4 motor (you can fill in the make and model). I have young kids and its great to have the 4 doors to get them in and out of the truck. However as a "Truck" this thing is completely useless: - The shortbed is too short that you can't transport anything. My wife bought patio furniture the other day and I almost had to make 2 trips because it didn't fit - Any heavy weight in the bed and the suspension sags and the steering gets all light on the road - Even just the weight of an empty trailer causes the suspension to sag and messes with the steering. The engine is powerful enough to increase your towing capacity and it can pull the weight. I just feel that the truck is too light and I don't feel comfortable on the road for long distance. |
since you already had the ideal pulling truck, you know the obvious answer..
but if you're looking for cheap, light, and comfort, 1/2t will handle that 4500lb rig all day no problem.. to make your tow as safe as possible, I recommend brakes on both trailer axles.. they usually only have them on the rear, have a local trailer outfit install one on the front.. weaker brakes is the biggest downfall I see with lighter trucks towing.. although at 4500lbs you'll be well withing safe limits on a 1/2t, extra braking over mountains and steep grades is a nice safety factor, especially for only a $2-300 axle.. I also recommend a good controller, if the truck you buy doesn't already have an OEM installed, prodigy is one of the best out there.. this is an old '02 GMC 1500 with 5.3, towed ~7500lbs frequently from baja to mojave no problem other than predictable trans which made it to around 120k miles and still drove to trans garage.. mine being early, also had the weak heads that both cracked and started drinking a gallon of coolant a week.. cheaper for me to replace the engine than both heads on 150k mile engine so swapped it.. but even with both heads pouring coolant out, drove it to father in laws shop in henderson 90 mph in 115 degree heat only stopping for gas once and water three times :lol: at 190k miles, still drive it daily.. paid off in '04 and that was the last car payment I'll ever have :) bottom line is they have plenty of power and longevity with sensible driving, normal person probably could easily double my results :lol: good luck! https://dl.dropbox.com/s/i3jcgyhlkib...02389.JPG?dl=0 https://dl.dropbox.com/s/vhh0tkwz70a...024sm.jpg?dl=0 https://dl.dropbox.com/s/vvflj5pn4q3...05607.JPG?dl=0 |
[QUOTE=Killer Bee;8575575]since you already had the ideal pulling truck, you know the obvious answer.. but if you're looking for cheap, light, and comfort, 1/2t will handle that 4500lb rig all day no problem.. to make your tow as safe as possible, I recommend brakes on both trailer axles.. they usually only have them on the rear, have a local trailer outfit install one on the front.. weaker brakes is the biggest downfall I see with lighter trucks towing.. although at 4500lbs you'll be well withing safe limits on a 1/2t, extra braking over mountains and steep grades is a nice safety factor, especially for only a $2-300 axle.. I also recommend a good controller, if the truck you buy doesn't already have an OEM installed, prodigy is one of the best out there.. How do I know if the truck is already built with a controller in it? Is this an option that I would have to read up on or is the controller visable under the dash ? good luck! [ |
I suspect they are predominantly installed by OEM with tow packages but I'm not sure what years, models, etc.. https://www.gm-trucks.com/forums/upl...3899_thumb.jpg eta, pic above not showing on my phone? this is in my 2012 gmc 2500hd work truck https://dl.dropbox.com/s/jr171c47ddp...54846.jpg?dl=0 this is what I installed in my '02 and it works great.. controls up to 8 brakes [4 axles], easily adjusts, has brake boost mode button, digital display brake voltage, etc.. look at amazon, etrailer, etc, hundreds of 5 star reviews, definitely my top choice if not OEM equipped.. this popped up in my search BEST BRAKE CONTROLLER REVIEWS – TOP-PICKS good luck! https://dl.dropbox.com/s/i3g7rvroegy..._4833.jpg?dl=0 |
My 1500 5.3 4x4 would pull that 4500 lb trailer fine and it has a factory (adjustable) brake controller. I am always more concerned on the woah over the go so trailer brakes are a necessity. However, I think the 5.3 is lacking in the torque category and the 6 liter makes up a bit for that. In the hills or mountains you would not regret the larger engine.
Also, for pulling the rear suspension on the 2500 is more than enough to handle the load but is your trailer 4500 listed on the nameplate? Your actual, loaded weight will most likely be a good bit more than that once you get it loaded with all your travelling needs. If you are going to drive the truck more without the trailer perhaps you would like the lighter truck better. If it's primary purpose is to pull your loaded trailer, I still like the 2500 option. |
the air bags work great! 10psi per 100lbs lift.. I opted for simple valve stems under rear bumper but onboard compressors with gauges etc. readily available.. air bags are great for adjusting heavier loads and leveling out.. even heavier trucks could take advantage of this but often overlooked.. this would have been rough without airbags.. and mine are old and don't hold very well very long but made this trip down the mountain from ojai to orange county much less stressful :) level wheel wells on truck and trailer sail much smoother! good luck! https://dl.dropbox.com/s/82jvcx19w15...49516.jpg?dl=0 |
I hate spending others money, but since you asked...I'm in the same situation and decided to buy a 1/2 ton Ram with the Hemi. What we think we're getting for a trailer is quite similar to yours. Plan to use a weight distributing hitch and make sure both trailer axles have brakes. If there's an upgrade to the truck brakes be sure to spend that money.
23' is a short trailer and 4500 lbs is light. I have pulled my 33ft RV at 5500LBS dry with my 08 Silverado from one side of the country to the other and it did fine. I have had it on mountain passed and it did fine. Just add a good transmission cooler and have the correct gearing. I have a 4 speed with 3.38 gears and 3.73 would make all the difference.
You can make many upgrades to the half ton that will make it nice, Sway bars, Hellwig and air bags. The list goes on. A 2500 will always be better hands down. Can't compare the two. A 14 will most likely have a 6 speed and you can find one with the bigger displacement engine if needed. Ether way I think you will be happy towing with ether one. Think forward as well, Will you be getting a bigger RV in the future? If so, plan for that when picking the truck. My 2 cents. As talked about, Weight distribution helps a lot. Don't cheap out on that, get a quality one without the chains. |
We recently bought a 2018 Tahoe (2014 would be similar) and it has the 5.3. I have pulled 2 camper trailers, 1 2300 lbs and 1 3500lbs. I also sold my LS swapped '86 Cutlass earlier this year and delivered it to Ashland,OR on a Uhaul trailer. I feel like it's done really well with all the different trailers and I'm really happy I got the factory brake controller and self leveling suspension, this also has a built in engine brake which has kicked in even towing the smallest trailer I have. Which seems to really help with braking
Like it was said above, I'm more concerned with the braking then the power. Whether you get a 1500 or 2500 I would highly recommend you find one with those options if you can. |
If your not dead set on a pickup many of the newer SUVs will pull that trailer . With liquids and gear your rig would probably be around 72-7300 pounds.
The lightweight should not be a problem for any of the half tons as long as you don't load the bed with lot's of heavy gear. Get a weight distribution hitch kit, they're a couple hundred bucks. Plus have it setup correctly from a camper or hitch shop. Get a trailer brake, test it when you start your road trips. Go slow in the wind with a lightweight! I would really test the turning radius of the 4x4 trucks vs the 2wd. A good turning radius makes backing into tight spots easier.
Have fun! :chevy: j |
My two cents.
2500, 2 or 4 wheel drive, with a 6.0 engine, brake controller, equalizer hitch. I have both 1500 with 5.3 and 2500 with 6.0. The 1500 will do the job just fine, but the 2500 will do it that much easier. I love the integral brake controllers. They just work better than an add on controller. |
The 2500 have bigger brakes don't they? Heavier springs for sure. I sometimes think I should have shopped even longer trying to find a 2500 with 6.0 to handle our towing a little easier. My 1500 crew does the job but I do baby it under load. I don't want to strain the trans or brakes.
I have towed boats, campers, car trailers, etc. all my life. I switched to Ram and Dodge years ago simply because they are better for towing. A Ram 1500 standard 5.7 has 395 hp and 375 ft. lbs. of torque (what you need for towing) and an eight speed trans. A 5.3 has 285-310 hp and 325 ft lbs of torque. I have a 27 ft pull behind camper now and pull it with my Durango SRT (475 hp and 470 ft. lbs. of torque) simply because it is lower and easier for my wife with MS to get into. I have always had pickups and if I bought another it would be another Ram due to its engine and superior towing ability. I wish that they would put the 6.4 that is in the Durango in a 1500, but you have to go to a 2500 to get it and it is slighty watered down from what is put in my SRT. In any event, I suggest that you take a look at a Ram also. You are a veteran tower so you don't need to be told about hitching etc.
[quote=jeffahart; I would really test the turning radius of the 4x4 trucks vs the 2wd. A good turning radius makes backing into tight spots easier.
Have fun! :chevy: j[/QUOTE] I either forgot or did not know that 4/4's do not turn as sharp as 2 Wheelers.. I had a 4/4 and 24 ft travel trailer and a couple places this might of came into play ,,but only a couple . Quote:
Whats your thoughts on th1s truck 2007 GMC SIERRA 2500 CREW CAB 4X4 SLT DURAMAX DIESEL ..It's a 6.6
How many miles is to much for this year .. I know if it been taken care of matters a lot ,,but there is one for sale close by fir $21,950 and i am waiting to them to get back with me on the mileage.. What if it is say,,135k is this a truck you would buy and use for pulling this trailer I bought I know I didnt want a diesel ,,just curious about it here is another one ,,2007 GMC Sierra 2500 HD Crew Cab SLT Pickup 4D 6 1/2 ft (125K) and it has the 6 L engine |
It's not like a 2500 is too much truck to drive empty. The ride is great for what it can haul and not much different from a 1500. Also, fuel consumption difference is negligible. So why not get another camper hauler 2500 that is fine to run about in when home? That's the best package for someone who owns a travel trailer, IMO. A 1500 truck can do it and so can an SUV, but the 2500 does it better. I also like the idea of full-floating rear and would want that. The single rear 3500 I had drove and rode nice as a 1500, so it wasn't overkill but it was better
Larry, as you know, we bought my Duramax new. It just turned over 250,000 miles. I drove it to Florida two weeks ago and it got a solid 22 MPG driving it like an old man.
I just now got back from Missouri with a load of sod on my SIL's new Ram (Dodge) and it is pretty impressive. WE have a couple of the Ram 2500's with the 6.4, and they pull a lot stronger than the 6.0 GM trucks. Sounds like a Dodge commercial don't it? I have had several chances to move to a new truck, but I'm more than satisfied with my old Duramax. |
Talked my brother into getting a 3/4 ton 2wd crew cab non-mega cab Dodge new (2014), and it was less than 30k - no regrets at all
If you already have a Tahoe, I would just beef it up with overload bags, & stabilizer. It doesn't sound like you need a dedicated truck to sit most of the time. |
