Need to raise rear 1"-1.5" after flip kit
Rear sits a little too low after flip kit/notch install. Should I go with lift shackle or Air shocks?? running stock shocks with extenders now (need to replace shocks anyway)
Re: Need to raise rear 1"-1.5" after flip kit
i may be mistaken, bu the hackle would need to be shorter to lift now...cant get much shorter than stock...
the flip was too much, you should have used a shackle / hanger combo or rear leafs. the air shock will get the lift, but you will quickly hate the ride. |
And the do make a "hackle" that is shorter than stock that's advertised as a 1.75" lift. |
Rear lift shackle will only raise it half an inch.
forgive my ignorance....mine has been bagged and linked for over 10 yrs, couldnt remember how the rear was stock.
You could also relocate the shackle hanger. Dropping it down should yield some drop. You'd need to be creative to brace the hanger bracket (since it would hang lower) but that shouldn't be too difficult.
Shackles, for sure. Air shocks should be left in the 70's. If you just have to have air, helper
bags are the only way to go. |
Air shocks worked great ... raised up the 1"I needed and the ride is not bad at all!
I would have gone with aux air bags. They'd do the same thing as the air shocks but leave you with better suspension action at given height.
I can't imagine those shorter shackles would allow much action that shackles are intended to give. I think the lesson here is on leaf rear trucks when lowering, do the rear first then match the front. You have more options for getting the front where you need it |
The thing with air shocks is they are loading brackets that were never designed to handle weight. Fine for empty trucks, but I wouldn't want to use them on trucks being used like trucks.
i would concur with that point, but being a light duty lowered truck, it probably wont be an issue.
My Dodge on the other hand, spun an axle tube after i beefed up my shock mounts. Guess the 2.65 Bilsteins were just to much |
If you are planning to not do a "mechanical" means of raising the inch I would suggest something similar to what I am using on my truck. My purpose was more of a way to maintain the ride height with some weight in the bed, however it would work fine for what you are doing & place the force to where it better belongs (not the mounts of the shocks as mentioned) Lorne
https://beta.photobucket.com/u/HAULI...c-f12427ea611a |
