4l80e trans in K10 - Transfer Case Adaptor - Tone Ring ??’s
Swapping 2004 lq4 with 4l80e trans into my ‘72 K10 w/ 350/TH350 and NP205 transfer case. Advance Adapters makes a kit to mate the 4l80e to the NP205 transfer case. However, AA says the 4l80e will require a tone/reluctor ring install - which sounds like a pain in the a$$. Is there any way around the tone ring installation?
Re: 4l80e trans in K10 - Transfer Case Adaptor - Tone Ring ??’s
https://www.novak-adapt.com/catalog/...e-to/kit-4l81/ The tone ring kit is available from Novak Adapt...the link has all the details... I assume you will be using a standalone trans controller... :chevy::chevy::chevy: |
I’m trying to avoid the tone ring install. Is it possible to use the transfer case from the donor ‘04 vehicle? And then eliminate the tone ring issue altogether?
Posted via Mobile Device |
And I hope to use the stock ECM.
You are correct. Wrong side. Just trying to think this through b4 I spend any more than I have to.
I will be doing the same swap LQ4/4L80E in my 72K2500. Try to find a 205 from a square body that had a th400 in front of it, they are hard to find but that the ticket. I got lucky and found one and it's a direct bolt up. The 4L80E is a th400 with overdrive and the bolt pattern on the tail and spline count are the same. Somebody please correct me if I'm wrong
The ORD link above has good details on the NP205 |
If you get a stand alone controller you don't need the tone ring in the t-case. You can program it to use the rear speed sensor in the trans. If no sensor in the transmission you'll have to install one. Worst case is no tone ring internally. If that is the case, then you'll have to have a trans shop put one in
Thanks for all the input.
