72 gmc Sierra grande stuck in 4 wheel drive
I have a 72 gmc Sierra grande 1/2 ton 4x4 that is stuck in 4 wheel drive. It has a 205 transfer case. I cant get the transfer case shifter to move and the hubs wont unlock either. Any suggestions or advise?
Re: 72 gmc Sierra grande stuck in 4 wheel drive
Prolly shift linkage froze. Spray some penetrating lube on the pivot and the cross bar where hooks to the shift rails. I had one freeze on one. Hubs won't unlock cause there is tension on the driveline.
If it's been driven on a hard surface (like pavement) the driveline might be bound up. Try driving slowly in reverse while steering left & right. If it's still bound up you might have to jack up a front tire, then you should be able to release that hub and take the TC out of 4WD.
Thanks I will try those things!
i like napa chain and cable lube . its a foamy oil that sticks real good for lasting lube . also spray the rails that go in the case the link bar is hooked to .
as said she is just bound up a bit . |
any update?
